When I press play on a deck, the song speeds through (happens on both decks with any song I put on). It plays the entire song in about 10 seconds. I can't seem to find the setting to change this. I even restored factory settings thinking I changed something I shouldn't have. How do I fix this?
geposted Sat 23 Jun 12 @ 12:09 pm
One of the song fast search (Seek) buttons may be jammed down (>>)
Try pressing it to to release it.
geposted Sat 23 Jun 12 @ 3:42 pm
Nothing was depressed. However I figured out the issue. I also have Serato SL1 hooked up. Even though I wasn't using it, it was the issue. As soon as I unhooked it, no problems. What was weird is that when I had everything hooked up before when using the LE version that came with the MC6000 no problems. However the issue started after I installed VDJ Pro.
geposted Sun 24 Jun 12 @ 9:03 pm
