This may be possible but have not been able to find. I am accustomed to listening to a song in cue setting the correct bpm then automixing to that deck. The sync feature works fine but is manual mode. Also, I've had problems with the tempo slide working then not working on my mc6000 while operating laptop in USB mode. To correctly set tempo I have to use the slides on the laptop screen. There seems to be no rhyme or reason for the occurance. I can switch to a different deck and the slides on the controller work fine. Don't know whether problem is software or hardware.
Back to the automixing between two decks. The main reason for cueing a song up at correct bpm on another deck is being able to leave the booth
and know the next song will be at correct dance speed.
geposted Sun 24 Jun 12 @ 2:27 pm
dunno if this is what you looking for.
Automix_Dualdeck
Automix_Dualdeck
geposted Sun 24 Jun 12 @ 4:13 pm
I found what you were talking about in an earlier post. I'll Find out if it will do what I need.
Thanks
Thanks
geposted Sun 24 Jun 12 @ 7:45 pm
Kinley,
Make sure that when you alter the pitch slider on a newly loaded song, you need to first go back to the center so that the software slider can resync to the hardware slider. This might seem annoying, but consider the alternatives which would be either that songs load up and begin at the pitch of the slider (as would happen on an old turntable,) or that songs load up and play at 0% pitch and then jump to the pitch slider position as soon as you start moving it.
I hope that helps.
-Frd
I hope that helps.
-Frd
geposted Mon 25 Jun 12 @ 12:14 pm
Please see our FAQ pages:
https://virtualdj.com/wiki/Soft%20Take-over%20or%20Non-MIDI%20Mixer.html
https://virtualdj.com/wiki/Automix.html
Please be aware that the old dual-deck automix is long since depreciated and its use is not recommended.
geposted Wed 27 Jun 12 @ 5:27 am
