Hi, this is my first post as a user.
I have a new 15 inch macbook pro and I'm running the latest vdj pro. I've noticed that when I change the effect on either of the 2 decks the whole moving section of the display stops until I click on the effect I'm wanting to use, sometimes for quite a few seconds afterwards.
Is this common?
My mac is running os x 10.7.4, a 2.2 Ghz Intel Core i7 and 8 Gb of RAM and I'm using a Hercules RMX with the latest firmware...
Thanks in advance
Is this common?
Thanks in advance
geposted Sun 24 Jun 12 @ 5:24 pm
No it's not ;-)
Have you enabled to use the highclass videocard all the time?
Does this come up, while using one special effect or is it always?
BTW:You use the latest Hercules driver and settings?
https://virtualdj.com/wiki/RMX.html
geposted Wed 04 Jul 12 @ 6:49 am
Hi, It happens when I click on the drop down arrow next to the effect so I can select a new effect, it happens on either deck and any time I change the option. Im also new to the mac platform and don't really know my way about the computers settings etc so any help you could offer would really be appreciated !
geposted Fri 20 Jul 12 @ 5:12 pm
Please have a look here:-) hope this will help.
https://virtualdj.com/homepage/Haui70/blogs/4766/Macbook_Pro_OSX_video_settings_.html
geposted Tue 24 Jul 12 @ 6:20 am
