Forum: Old versions
Topic: Left Scratch Wheel does not Work
Just installed the ION Discovery DJ, using the included software. The left wheel does not give me any movement, no scratch but the right wheel works perfectly. Is this a setting I'm missing or does this need to be returned?
geposted Mon 25 Jun 12 @ 11:30 pm
Try using a MIDI tracing tool such as https://virtualdj.com/download/miditrace.exe to check that the jogwheel is sending MIDI messages (Click on the Discover DJ in both the input/output sections and then move the left jogwheel.) You should see MIDI messages as you move it. If not, then it may be faulty and will need to be returned back to the store where you purchased it for replacement or refund.
What is the included software? If it's VirtualDJ and the jogwheel is sending MIDI messages OK, then please see the following pages:
https://virtualdj.com/wiki/Vinyl%20mode%20is%20turned%20off.html
https://virtualdj.com/wiki/Smart%20Scratch.html
https://virtualdj.com/wiki/Reset%20controller%20back%20to%20default%20factory%20mapping.html
If the software is not VirtualDJ, please go to the maker's website for assistance.
