Does anyone know how to get VP6 Avi files to play? Did K-lite change something in later versions which disabled this?
I was formerly able to play these avi files with VDJ on an older computer but now on my new Win 7 (64) laptop I have no luck.
I also tried to play these in Windows Media player and also Media Player Classic on several computers including a Vista (32) machine with no luck.
Also tried VLC player with no luck. In VDJ I changed the codec for avi to windows media decoder and so on. I have the latest version of K-Lite (86 & 64 bit) versions installed. Can anyone help me with this? TIA!
BTW the sound does play but the video does not play...
geposted Tue 26 Jun 12 @ 11:21 am
Dunno if this will help but worth a try
install the vp6 codec.
http://www.free-codecs.com/download/vp6.htm
geposted Tue 26 Jun 12 @ 1:42 pm
Thx but no luck!
geposted Wed 27 Jun 12 @ 6:34 pm
is the extension vp6 ?
if it is vp6, VDJ will not see/know what that file is until you add it.
Try adding vp6 and use codec VDJ Video Codec, if that won't work, then try Windows Media codec.
geposted Wed 27 Jun 12 @ 10:30 pm
The extension is .avi however the codec according to media info is vp6 (vp61). Is there a way to directly get VDJ to utilize the ffdshow decoder? This apparently is supposed to decode vp6 and other flash video formats.
I read somewhere also that the vp6 decoder sometimes was buggy and needed to be installed with the windows UAC turned on. I tried this with no luck either.
Again this use to work on my vista 32 older dJ computer with an older version of k-lite. In VDJ it worked before by using the Windows Media Decoder (aka the generic windows decoder).
I think I might try cherry picking the older version of the vp6 dll in the sys32 directory of the old computer and copying it to the new one... I'm not even sure what it's called though lol
geposted Thu 28 Jun 12 @ 2:29 pm
Oh VDJ codec gods any suggestions?
geposted Mon 02 Jul 12 @ 7:51 pm
Did you ever get this resolved having same problem
geposted Sun 10 Feb 13 @ 2:29 am
What problem?
In the OP he couldn't play the files outside of VDJ either, so it suggests his problem was elsewhere.
If you change the file extension to windows media player video decoder then its up to your system to decode the video by the way of direct show filters.
geposted Sun 10 Feb 13 @ 7:34 am
