Forum: Old versions
Topic: Creating tracks to move automatically
I have Mixlab installed with VirtualDJ but now I want to set specific points (I believe they are cue) so that the next song gets played at the runtime that I wish in a playlist that I've created. I do not want Automix to be activated because that predetermines where it should mix from.
How do I automatically at points that I wish to occur:
let the other track start
move the bass crossfader at one deck to another
reduce the volume of one deck
Thank you :) Sorry if this has been repeated but all I saw were automix options.
geposted Tue 26 Jun 12 @ 11:50 am
use 2 decks then use Automix_dualdeck.
Please see our FAQ pages:
https://virtualdj.com/wiki/Automix.html
When using the standard single deck automix, you can adjust the automix markers on the song overview waveform to set the points where the current song will mix out and the next one will mix in.
Please be aware that the old dual-deck automix is long since depreciated and its use is not recommended.
Is there a tutorial to make this more easier? I'm sorry, but I seem more lost when I read the guide. It still happens automatically and chooses its own generated Automix points, even though I set up the points where I want it to mix.
Thank you :)
