Hi Everyone,
Many of the effects available have active buttons and sliders for real-time adjustments.
I would like to map a button on my mixer to toggle between two effect buttons, and also if I hold the mixer button down it will act as a shift for a knob.
I would like the knob to control two of the effect sliders (one normal knob controlled effect slider, and one shift knob control of the second effect slider while the shift button is held down).
My mixers mapped button and knob should control each effect individually (I may want the knob to control slider 1 in effect "A", but when I switch to effect "B", the knob may need to control slider 2, etc).
Hopefully I explained it OK.
Thanks for your help.
Clay
Clay
geposted Tue 26 Jun 12 @ 4:14 pm
set $effectmode while_pressed & toggle 'over' & effect 1 select 'overloop' ? var 'over' 1 ? effect 1 button 2 : effect 1 button 4 : effect 1 select 'ramp_delay' ? var 'over' 1 ? effect 1 button 1 : effect 1 button 2 : effect 1 select 'beatmasher_single' ? var 'over' 1 ? effect 1 button 2 : effect 1 button 3 : effect 1 select 'efx1000_delay' ? var 'over' 1 ? effect 1 button 2 : effect 1 button 4 : nothing
you can continue the script as far as you like before nothing at the end. the formula is
effect 1 select 'effect_name' ? var 'over' 1 ? effect 1 button 1 : effect 1 button 2 :
the way it works is it changes to operation of the buttons dependent on the effect selected in slot one, If you are using a skin with only 1 effect slot it will be the "maineffect" so you will need to change " effect 1 select" to "effect select" for it to work.
geposted Tue 26 Jun 12 @ 6:17 pm
Thanks again Synthet, that string did exactly what I needed! :)
You da man!
Clay
You da man!
Clay
geposted Wed 27 Jun 12 @ 1:16 pm
