I s Xone: K2 mixer compatible with Virtual DJ or should I go with the X1?
geposted Thu 28 Jun 12 @ 12:02 pm
It's a USB MIDI device, with a USB soundcard. It'll work with any software that supports USB MIDI devices.
If you read what it says on the Allen & Heath website, it tells you the same thing:
"Xone:K2 is a universal MIDI controller and is perfect for use with any DJ software, such as Traktor Pro, Ableton, Virtual DJ, PCDJ and MixVibes"
geposted Thu 28 Jun 12 @ 4:56 pm
I tried to score a free one off Allen & Heath earlier in the year to create a mapping for them... They declined :-( but said they have been in contact with atomix about mapping it so it should be natively supported at some stage. If you need I have already made a full definition from the midi implementation chart in the manual but need the device id's to make vdj recognise it.
geposted Thu 28 Jun 12 @ 6:51 pm
I scored a Xone T shirt off A&H at BPM last year and that wasn't easy. They might be a bit more willing if you were David Guetta.
geposted Fri 29 Jun 12 @ 4:43 am
Thank you guys for the infos. I wish this controller was already supported.
geposted Sun 01 Jul 12 @ 10:11 pm
It is supported.
It's a MIDI device.
VDJ supports MIDI devices.
Plug the K2 in to the computer using a USB cable. Install A&H drivers if required. Open VDJ. Go to the mapping page. Map the K2.
It's a MIDI device.
geposted Mon 02 Jul 12 @ 4:46 am
groovindj wrote :
It is supported.
It's a MIDI device.
It's a MIDI device.
I meant to say natively supported. I am still thinking about getting as of yet.
geposted Mon 02 Jul 12 @ 8:08 am
What you have to bear in mind is that the K2 does not have a set format for what its controls do.
It's a blank canvas. You use it for what YOU want/need, not what someone else thinks it should do.
Do you see what I mean?
Say the K2 did have mapping included in VDJ. What are the chances that it would be mapped to exactly the functions you needed?
If it wasn't, you'd have to map it yourself, right? You can do that now!
geposted Mon 02 Jul 12 @ 9:06 am
The XONE:K2 will have a mapping in the near future provided by us. And it will definitely be native in version 8.
geposted Fri 06 Jul 12 @ 2:13 pm
Thank you Cstoll for the infos.
geposted Fri 06 Jul 12 @ 8:12 pm
hi there,
you mentioned that you would release mappings for the k2 in virtual dj a while ago, any progress with that. im not so good with programming and creating xml files etc.. and i would love to get full use from my k2!
geposted Mon 19 Aug 13 @ 8:07 pm
Atomix already stated that the current version of VDJ 7 will be the last before 8 is released, so there won't be any K2 mapping added before VDJ 8 (which shouldn't be too long now, based on what's been said at the recent DJ Expo).
You will need the full VDJ Pro in order to use the K2 though. The basic versions don't support controllers.
geposted Wed 21 Aug 13 @ 6:35 am
