Occasionally, one will just stop playing. sometimes it will "pause" and I can continue where it stopped. Other times, it returns to the cue point. Using windows 7 and (I believe) Virt DJ 7.
geposted Fri 29 Jun 12 @ 10:22 am
Er.....so how are you using the CDJ400s?
As MIDI controllers over USB, or with timecode CDs?
geposted Fri 29 Jun 12 @ 3:23 pm
Sorry... midi with USB
geposted Fri 29 Jun 12 @ 8:25 pm
Have you notice if this happens with a particular device (from the 2 you have) or both ?
geposted Fri 29 Jun 12 @ 8:40 pm
I am rotating between 3 decks (with 2 connected at any time). It seems to happen with all 3. But, always on deck 2. Maybe a USB issue?
geposted Mon 02 Jul 12 @ 10:53 am
It appears that it loses connection for a while. Could be a bad USB cable ? Are you using a USB hub ? It is suggested to connect those devices directly to USB computer ports.
Also make sure Windows are not disabling the USB port for power saving reasons.
You change that in Device Manager-->Rightclick on the USB Hub-->Properties->Power management tab (unselect the option)
geposted Mon 02 Jul 12 @ 1:44 pm
