I have virtual dj pro 7 and vdj7 home. The Audio quality on home is much better than the audio in pro. Can anyone help me?
geposted Fri 29 Jun 12 @ 4:15 pm
Both softwares versions have the same Sound Engine.
If you have purchased Pro Full version, please register the serial number to your Profile https://virtualdj.com/users/edit.html and download the latest Pro Full version from your Download Center https://virtualdj.com/download/updates.html
If not purchased, please do that here https://virtualdj.com/buy/ and support the software and its future development.
geposted Fri 29 Jun 12 @ 9:11 pm
Sounds very strange if you're using the same computer, playing the same song file but getting different sound on the home version and the pro version.
I guess you must have some settings different somewhere in the 2 versions?
Just some guesses in case you're stuck and need a starting point:
check that key lock is either on/off in both versions (It's the padlock above the pitch slider).
Go to the "options" page of the config in the pro version (I'm not sure if the home version has an options page) and make sure everything is set to "high quality"...
I'm out of easy ideas now, sorry!
Oh yes, and make sure you test both versions by playing the same song at 0% pitch so you're compasion is fair. Maybe you could hook up something to record the output (like another laptop with a line in socket) so then you could hear side by side the difference and even upload it so other people can hear what you're talking about.
geposted Sat 30 Jun 12 @ 5:10 am
