Hi all,
Just started a new skin from scratch, designed for the Hercules RMX.
The rhytmzones in the decks are videopannels to.
Nearly all textzones are klickable.
Maby I remove the round sliders because they are on the console.
Well... If you have ideas......
Best regards,
John
Best regards,
John
geposted Sun 01 Jul 12 @ 3:20 am
I think you should add the DJC Buttons.
Those can have different actions, so its useful to see what action is/can be assigned to each one of them.
If you need to save some space, you could get rid of the EQ knobs. Those are present on the console as well :)
geposted Mon 02 Jul 12 @ 1:06 pm
Hi,
Latest update.
The djc_buttons can be controlled with the (rmx) console but in the skin you can't. Then a click is 'select'.
Latest update.
geposted Sun 08 Jul 12 @ 5:51 am
