I am using the iRemote with my iPhone 4
I want to get an iPad for the iRemote
1) is the iRemote going to work as well on all three versions of iPad, in fact can be use with the iPad first gen?
2) is the multitouch supported on the iPad?
3) is the search function working on the iPad version?
geposted Mon 02 Jul 12 @ 8:44 pm
1) Not sure, no-one has reported using it on the ipad 3. The vast difference in screen resolution probably means iremote will appear in a smaller window or be horribly stretched. Works perfect on the ipad 1/2 however.
2) No
3) No
Maybe development of the app will happen sometime in the future but at present it's pretty much as it was at day one.
You can use RDP options like splashtop remote to achieve pretty much the same thing and have browser functionality too. This also allows use of standard VDJ skins as all you're doing is emulating your computer desktop.
Keith
2) No
3) No
Keith
geposted Mon 02 Jul 12 @ 11:48 pm
it works flawlessly for me on new ipad :-) have tried most of the skins and there are no issues
hope it helps
hope it helps
geposted Tue 03 Jul 12 @ 10:50 am
Thank you for your comments.
I thought that a skin was in the works that should have a way to search, is that not finished yet?
geposted Wed 04 Jul 12 @ 1:55 am
That is not the case. There is no search function built in to iremote and a skin can't change that.
Keith
Keith
geposted Wed 04 Jul 12 @ 2:18 am
