Hi all -I have been working on this for a few hours, very frustrated and need help. I am using VDJ 7 Pro with a Numark NS6 and a Macbook pro. I believe I have updated the drivers and the firmware through the Numark site. I am using the NS6 skin. Itich was loaded on the Macbook pro but it is NOT being used.
I have read the posts about the left SYNC button not working and have tried all the suggestionsand configurations that I have found. I cant get it to work. I can use the sync button to get channel 2 to sync with channel 1 but it does not work when I use the sync button on channel 1 to sync with channel 2.
I have also loaded the VDJ7 4 controller skins to set the master but tha is no help.
My sound set up in VDJ is :
Input: None
Output : Headphones : Master channel 1&2 \ Headphones channel 3&4
Sound card: 4-out card : Numark USB Audio Device
Am I missing something ?
Any help would be appreciated. Thank you.
Input: None
geposted Wed 04 Jul 12 @ 2:50 pm
Yes... Look for the "MASTER" (above the play button). When selected, it light up in orange. That means that's the masterdeck. Whatever the bpm on that deck that's the one to be copied from the any deck that you press the SYNC button.
Hint: Try Cstoll's mapper (3-1-2-4 deck arrangement) if you haven't yet. There's a lot of cool functions that you will surely enjoy.
Cheers! and Goodluck!
geposted Thu 05 Jul 12 @ 11:49 pm
Cool Thanks, ... I'm VERY Noobie ... Is there any way to change the masterdeck from the NS6 hardware ?
Is there a better way to do it ? Or is Cstoll's mapper the best way to go ?
geposted Fri 06 Jul 12 @ 1:58 pm
If you are running the LATEST version of VirtualDJ - you should not need to download the mapper at all - as the mapping is already supported in VirtualDJ.
You may want to download the PDF though - https://virtualdj.com/addons/download/src/13230/NS6-VIRTUALDJ%20Manual%20-%20v1.0.pdf
What would you change the masterdeck control to, if not using the NS6 ?
geposted Fri 06 Jul 12 @ 2:11 pm
