Hi,
I have currently got Virtual DJ 7 LE edition that is connected to my Pioneer DDJ Ergo.
However, I have a Saffire 6 USB audio interface and want to connect this to my Pioneer DJM-600 mixer and use Virtual DJ.
How do I do this?
Thanks
Tom
How do I do this?
Thanks
Tom
geposted Thu 05 Jul 12 @ 4:35 pm
I assume that the soundcard you speak of is external???......I'm not understanding why, when it is plugged in (I assume by USB) that it does not appear in your "output options" under "sound" in Windows?....Please be more specific with the exact problem. Do you know where to look for your audio settings?...Are you running Win 7?....Are you on a PC?.....etc....is the card external or internal to the machine you are on?.......Oh and almost forgot, one big problem that you might have getting certain soundacards to work with VDJ is tha you need to upgrade to the Pro version. (I think)...someone else will know for sure...it just seems to be the issue behind many problems on this board with limited edition users.....btw "Pro" is WELL WORTH the price....None of the others offer free upgrades, jus sayin....VDJ 8 is droppin any day
geposted Thu 05 Jul 12 @ 5:21 pm
VirtualDJ LE is limited software and only supports using the sound card built into the DDJ-ERGO with master + headphones.
If you wish to use external sound cards and/or separate deck outputs to an external DJ mixer, you will need to upgrade to the full VirtualDJ Professional at a discount: https://virtualdj.com/buy/
geposted Fri 06 Jul 12 @ 5:58 am
