Hi all,
Posted this in the wrong thread so will chance my luck here.
I'm having an issue in that I have downloaded some songs from Amazon. One of the songs is 8 mins in length but when I try and load this into VDJ it tells me the song is 16 mins in length and takes forever to load.
Any ideas as to why this is happening?
Thanks
Thanks
geposted Sat 07 Jul 12 @ 5:12 am
This is probably because they are variable bit rate files, so VirtualDJ doesn't know the correct length until the song has been loaded and analysed in full.
If it initially thinks that they are longer than your max load setting, then it will stream them from disk. See https://virtualdj.com/wiki/MaxLoad.html
To avoid this, make sure that you pre-analyse your music collection. See https://virtualdj.com/wiki/Pre-Analysing%20Your%20Music%20Collection.html
Also, see https://virtualdj.com/wiki/My%20songs%20load%20very%20slowly.html
geposted Sat 07 Jul 12 @ 1:41 pm
