Hi, I purchased the JBSystems Dj-Kontrol 3 Mixer with Virtual Dj LE and when VDJ LE is started the Mixer initializes fine, I then purchased Pro full retail but when I start Pro it does not initialize the mixer.
The mixer is connected via USB and I set both LE and Pro up the same, very confusing situation so any help would be greatly appreciated.
P.s. I'm reluctant to register Pro until I have it working properly incase of getting refund.
geposted Sat 07 Jul 12 @ 9:11 am
check what version you are using were up to 7.05 b380 where it is natively supported.
geposted Sat 07 Jul 12 @ 9:26 am
It says 7.05?
I'm going to try a re-install in case that works
geposted Sat 07 Jul 12 @ 9:44 am
if it doesn't say b380 then it wont work as that is the build it was added to vdj
geposted Sat 07 Jul 12 @ 9:48 am
Thanks for your help, I will proceed with registry and update.
geposted Sat 07 Jul 12 @ 10:19 am
VirtualDJ Pro is not available for sale retail - It can only be purchased on-line directly from us via https://virtualdj.com/buy/
Only Numark Cue, which is a Numark-branded version is available for sale in stores. If you have purchased this version, please register its serial to your profile on the page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
Please also be aware that because it is Numark software and updates must be approved by them, it is not the most recent version of the software. You can optionally crossgrade from Cue to the latest VirtualDJ Pro for only $49 by going to https://virtualdj.com/buy/
geposted Sat 07 Jul 12 @ 1:15 pm
