Does anybody know if virutal DJ is compatible with the pioneer ddj T1 controller?
geposted Tue 10 Jul 12 @ 2:20 am
Officially DDJ-T1 is not supported by VDJ. There is a device definition file + mapper available on the download section, but it offers basic support only.
PS: The reason DDJ-T1 is not supported is because NI wanted the controller to have some functions "locked" for usage with Traktor only!
On the other hand, DDJ-S1 is fully supported.
geposted Tue 10 Jul 12 @ 4:42 am
Yes the ddj-s1 works awesome with VDJ 7. Looks good event with the v1 skin.
geposted Sat 14 Jul 12 @ 10:25 am
Hi guys hope you can advise. I have been running virtual DJ7 on my win7 sony vaio and has become a little troublesome. These are the issues I am getting.
1 Sometimes as you move the cross fader from 1 deck to the other, you get as far as the middle of the fader and it mutes all of the sound and you have to quickly move the slider to the right side and then sound comes back.
2 Sometimes the track countdown counts up instead of down
and finally the volume controls when adjusted can suddenly blast out at full power for no apparent reason and if you turn the volume control to zero it makes no difference at all, still blasts out full on. The only way to stop it is to close application and relaunch it.
This problem is also apparent with tractor.
As an example last week set up rig tested all ok. Came back in the evening setup 1st track set volume level, hit play and it blasted out on full power, again had to close application and relaunch
geposted Fri 27 Jul 12 @ 7:16 pm
Sorry I have posted this in error on someone else's thread, if there is a moderator about please move it to new thread. apologies
geposted Fri 27 Jul 12 @ 7:20 pm
