I'm setting up my new laptop and copied everything from my old to new, Everything work fine, but I cant see my filter folders on the new laptop. Where is it saved on my old laptop ?, so I copy them to my new.
geposted Wed 11 Jul 12 @ 8:23 am
I think you'll just have to remake them
geposted Wed 11 Jul 12 @ 8:53 am
Assuming your music files are copied exactly across to the same place for example c:\music > c:\music there should be no issues.
Just copy your user > documents > virtualDJ folder from the old PC to the new one and you're good to go.
https://virtualdj.com/wiki/PC%20Transfer%20To%20A%20New%20Computer.html
Keith
Keith
geposted Wed 11 Jul 12 @ 9:02 am
Maybe you don't have "show filter folders" checked in the settings under browser tab. If you copied your VDJ folder over already I'd say that could be your problem.
Good day
Huey
Good day
Huey
geposted Wed 11 Jul 12 @ 9:05 am
That's a classic huey
geposted Wed 11 Jul 12 @ 1:23 pm
I can see the original filter folder on my new lap (Most Played, Recently Added & Compatible Songs) but not the ones I made on my old computer. I can see all my "Virtual Folders", "Playlists", "History" but not the Filter Folders. Maybe I have to do it all over again?
geposted Wed 11 Jul 12 @ 6:15 pm
