Hi
We have two denon 5500, what happens is one deck slows down slightly, here and there and the other speeds up megga fast.
These two senarios only happen when you put the decks into scratch mode, if you leave decks in bend mode its fine.
The problem then is cueing is quite difficult.
This topic may have been covered several times but cant seem to find a solution.
I believe this is a mapping issue, if so how can I rectify it so the speeding up of deck and slowing of the other does not happen. I just want to be able to scratch when required or drop tracks in with a minor baby scratch.
Kind regards
Cheers guys
Kind regards
Cheers guys
geposted Thu 12 Jul 12 @ 4:21 pm
