whts up everyone, im new to the forum, but i had a question, i have the full version to Virtual DJ, and im really interested in buying
the Numark Mixtrack pro, i know it comes with the Virtual Dj LE, but since I already have the full program will it work with the Mixtrack pro?
any help is apprecaited
geposted Sat 14 Jul 12 @ 6:50 pm
Yes it'll work.
Just make sure you're running the latest release.
Register your serial & visit the download center to download it!
J
J
geposted Sat 14 Jul 12 @ 7:53 pm
thanks alot j apprecaite it
geposted Sat 14 Jul 12 @ 8:41 pm
I have the same problem but have been told it works fine cant wait to get the mixtrack now
geposted Tue 24 Jul 12 @ 4:18 pm
controllers will only work for the first 10 minutes in VDJ Pro Basic, you need the full version to use controllers or you can use VDJ LE if it is packaged with the controller.
geposted Tue 24 Jul 12 @ 8:34 pm
Yes itll work been using my mixtrack pro and VDJ pro for awhile now and its awesome!!
geposted Fri 03 Aug 12 @ 3:08 pm
VDJ LE did everything I needed it to do & was very satisfied with the "limited edition" software. I do however highly recommend upgrading to Pro if you are running LE & can upgrade for the discounted price. Worth every penny. Serato Intro has some tough competition with VDJ. Seems like they're on that by releasing "Serato DJ" starting November 1st already tho depending which controller you use. People say it's more stable but I've never had a crash or even a glitch with VDJ Pro. Only difference seems to be the interface. I wonder if they'll even have skins, especially a VDJ skin
Cheers
http://soundcloud.com/urrit
http://facebook.com/urrit.stl
Some edits & mixes for free download on SoundCloud. Feedback helps me to always strive for better & is strongly encouraged. Feel free to contact me anytime.
Cheers & Enjoy
efrench1@gmail.com
Cheers
Cheers & Enjoy
efrench1@gmail.com
geposted Fri 19 Oct 12 @ 3:34 am
