I building a new facade and hope its as good looking as I envision it. The picture is how far along I am. Hoping to get it painted today! Primer is on both panels so far. These are 36\\\" x 48\\\" panels. I only need two for a 6 foot table instead of the normal three. I have the option to add another panel to either side for 9 foot, or side skirts of 12\\\" if I want (and will most likely add sometime).
The panel will be probably white spandex material for back lighting. The rails are two piece so replacing the screen/material will be quite simple if it gets torn or dirty. The top comes off (that is what all the little wooden inserts are for to hide the screws) and the material will lay in here and be held down by the top rail of the frame.
Thoughts on the design? I will post more pictures after they are painted and the fabric is on.
geposted Sun 15 Jul 12 @ 2:01 pm
