Hello, I hae used the Hurcules RMX in the past and enjoyed the performence. I traded the Rmx and upgraded to other gear for a while and found that i don't need to carry a lot of cumberson equipment for all gigs, so i have just purchased aother Rmx. Needles to say i am having major problems with the unit, I cannot get my laptop to recognize Rmx unit, the drivers will not load even after downloading the ipdates from the Hurcules site. it,s not my laptop because I have the same issue when I try to install the drivers on a second laptop I have. My system is running:
Toshiba L745
Windows 7 64 bit
Intel core i3 2310MCPU @ 2.10Ghz
4 gigs of memory
Please help if anyone is having the same issue or has solved this problem please, please, help me out. It is very frustrating especially on a brand new unit.
Toshiba L745
Windows 7 64 bit
4 gigs of memory
geposted Sun 15 Jul 12 @ 3:54 pm
If your issues are with the RMX and not VDJ you should try the Hercules site or contact their support.
geposted Wed 18 Jul 12 @ 3:35 pm
