Hello every body, I would like to know which is the best controller? I am new on this so I would like something good, I don't want to be professional but I want something good to enjoy and play at home or with my parties friend...
I was seeing in the site and have a lot of mark and model, so lets me know what is the best....
Thanks!!!
Thanks!!!
geposted Mon 16 Jul 12 @ 2:20 am
How much do you want to spend?
The best will probably be out of your price range.
Keith
Keith
geposted Mon 16 Jul 12 @ 2:32 am
I think any controller is good if you have a decent laptop. Controllers are just depending how serious you are about djing. You could spend 100 to 1000 on a controller but how you use it is gona define what kind of dj you are. Good luck on you're search...
geposted Mon 16 Jul 12 @ 2:59 am
geposted Mon 16 Jul 12 @ 5:55 am
go Mc 6000 or ns6
geposted Mon 16 Jul 12 @ 7:45 am
kpone9 wrote :
go Mc 6000 or ns6
But he doesn't want to be professional!
geposted Mon 16 Jul 12 @ 8:24 am
Why are you recomend NS6?
I will have to say that NS7 is the shit :D
geposted Mon 16 Jul 12 @ 1:34 pm
If its Non proffessional, Just simple parties at home etc, The Numark Mix Track pro is Enough. It has Rca Jacks so you can connect it to the Home stereo and you are good to go. Check in Craigslist for a good deal. I am sure you can get one for 180.
geposted Mon 16 Jul 12 @ 5:49 pm
If you are just mixing (no catch and release scratching) with a normal laptop, and you are only doing house parties or spinning for your people on the block these are the best controllers for the money for a starters
Numark Mixtrack Pro http://www.numark.com/images/product_large/numark_mixtrackpro_angle_large.jpg
Hercules 4Set http://www.hercules.com/us/DJ-Music/bdd/p/146/hercules-dj-4set/
Now if you are willing to wait a few weeks i would say check out the
Behringer Studio 4a http://www.djdeals.com/behringerCMDSTUDIO4A.htm it will be the cheapest fully loaded 4 deck controller on the market
or checkout the Hercules RMX 2 http://www.hercules.com/us/DJ-Music/bdd/p/193/djconsole-rmx-2/
geposted Mon 16 Jul 12 @ 7:25 pm
