Hi,
I'm just setting up a new install of VirtualDJ on a new laptop. I've copied all my music over, and scanned all the MP3 files. However, I notice the value in the 'Rating' column is not read by VirtualDJ.
I have rated all my tracks in another media program (MediaMonkey).
Why doesn't VirtualDJ read this tag?
geposted Tue 17 Jul 12 @ 7:04 am
Rating is an internal VirtualDJ database field. Not related with the Rating ID3tag one.
geposted Tue 17 Jul 12 @ 11:19 am
Why not?
Don't you think it should be, so it's compatible with other (tagging) software?
Or maybe someone could make a utility that converts standard ratings to non-standard (VDJ) ratings?
geposted Tue 17 Jul 12 @ 11:26 am
Yes, of course, it should be.
There could be a workaround though using some Plugin (Tool), but cant tell that for sure. Maybe some of the Plugin makers could answer that.
geposted Tue 17 Jul 12 @ 2:39 pm
It wouldn't be difficult to make a tool to convert them in either direction.
geposted Tue 17 Jul 12 @ 4:26 pm
If you agree that the Rating tag should be treated as a compatible field, does that mean you will add support in the next version? Or should I raise a feature request ticket?
geposted Tue 17 Jul 12 @ 5:01 pm
Proper and full tag support has been asked multiple times in the past. Unfortunately our policy is not allowing me to reveal any of the version 8 features.
geposted Tue 17 Jul 12 @ 7:39 pm
A nod's as good as a wink.....
http://www.youtube.com/watch?v=jT3_UCm1A5I
geposted Wed 18 Jul 12 @ 4:49 am
