I'm in the process of switching from PC to Mac
I DJ at a club where we use a Native Instruments Audio 2 DJ External sound card
On the PC, at the beginning of my shift I go to (in VDJ) Config > Sound Setup > Then under "Outputs" select "External Mixer" & under "Sound Card" select "Audio 2 DJ"
I have downloaded/installed the Audio 2 DJ driver to my Mac. However, While there is the option under Outputs to select "external Mixer", under "Sound Card" my options are only : "mono separated", "2 cards", & "4-Out Card". Audio 2 DJ is not an option. The "2 Cards" option seems to be expecting 2 cards inside the Mac.
Any ideas on how to resolve this??
geposted Tue 17 Jul 12 @ 1:05 pm
You need to select '4-out card' - This means a sound card with 4 outputs (2 stereo), i.e:
Inputs: None
Outputs: External Mixer
Sound card: 4-out card -> Choose the Audio 2 DJ in the drop-down list.
The 2 cards option as its name implies is for using two separate sound cards.
Inputs: None
geposted Tue 17 Jul 12 @ 1:23 pm
