Okay all this is my feelings on the Reloop Terminal Mix 4. I picked this unit up to replace my old xponent for backyard parties. For 2 days now I have played with this thing and I must say I do like it. All the knobs and sliders feel like a real mixer. All the knobs have the right amount of space between them for a good feel (that is very important to me) For a controller the sound card was excellent. The mapping for virtual dj was good but you will still need to put your on twist on it. I\'m not sure if the LE version has the same mapping that is in the download section for pro user (I am working with the pro version) The jogwheels feel better than the N6 and the pioneer ddj-s1 to me. I\'ve tested on windows xp 32bit and windows 7 64bit works great on both but I do believe it works better on windows xp. I hope I was able to help someone out that may want this unit
geposted Thu 19 Jul 12 @ 2:27 pm
Whats Good Audio. I messed around with the same controller and i was impressed. At first i found it alittle confusing because of all the buttons in the front, but got used to it right away. The Jog wheels feel really good and the controller is solid.
geposted Thu 19 Jul 12 @ 7:50 pm
did you scratch with it and was it accurate with catch and release scratching...
geposted Thu 19 Jul 12 @ 11:48 pm
I messed around with one at a Local DJ store. It was Running On DJ Intro software. At first when i was messing around with it, The Latecity seemed kind of high because my hand movement was alittle longer when i was trying to scratch. It was set to 1024ms. I went into settings and i lower the MS to 256 and it felt better. Touching the Jog wheel feels good because its nice in size and comfortable for a compact deck. From the setting it had it on (256ms), It felt good and i knew that if i had i better computer, it would perform even better.
geposted Fri 20 Jul 12 @ 1:35 am
Caliente (My Brother) I'm good bro
I'm not big on scratching but I will say this beat mixing with the Terminal Mix 4 was fun. And for a backyard party it will do great.
Would I take it to a club no but I would not take any controller to a club (That's Just Me). I needed a solid controller that had
good sound and knobs and sliders that felt like a real mixer most controller feel and look like toys to me but this one does not.
The DENON MC3000 and some other controller feel good but they are to small for me the Terminal Mix 4 is just right.
geposted Fri 20 Jul 12 @ 10:21 am
Why are the joggs so big? are you really going to scratch from it all night.
Other than that a bit hardcore for setting cue points, the RMX joggs are perfect for me.
geposted Fri 20 Jul 12 @ 6:21 pm
They do look big but they feel just right (Just like CDJs) ok maybe not just like CDJs but they
feel like you are playing on CD players
geposted Fri 20 Jul 12 @ 7:01 pm
Go BIG or go home Charlie, lmao!!
geposted Fri 20 Jul 12 @ 7:53 pm
I love the terminal mix 4...only issue im having right now is the "TRAX" button. when i spin it clockwise or counter clockwise it only scrolls up. if you go clockwise you should scroll dow through the folders/songs/etc. Anyone got a clue what the problem is? I didnt mess with the mapping yet, it loaded on default
geposted Thu 02 May 13 @ 12:16 pm
Make sure no files are in Documents\VirtualDJ\Devices folder
Goto CONFIG-->Mappers tab, select the Terminal Mix 4 from the list, and choose to revert to factory settings (button on the bottom of the window).
If it stills doesnt scroll properly, try to map the TRACK key as ..
browser_scroll
or
param_smaller 0% ? browser_scroll -1 : browser_scroll +1
or
param_smaller 50% ? browser_scroll -1 : browser_scroll +1
and see if that works.
If not, there might be a hardware issue. Please contact Reloop.com
browser_scroll
or
or
geposted Thu 02 May 13 @ 3:22 pm
can someone help me map my tm4 with virtual dj 8? pa and lease PLEASE.
geposted Tue 17 Mar 15 @ 6:12 pm
Sorry, home user do not have access to controllers. You will need to upgrade to Le or pro version.
geposted Wed 18 Mar 15 @ 11:43 am
Quick question... does anyone know if I can remap the sample buttons to work as additional hot cues? I'm so used to playing on SX/SZ and with my SP-1 I often find myself wanting to leave my samples on the SP-1 and just run the 8 hot cues from the TM4
geposted Fri 04 Mar 16 @ 10:29 pm
