Forum: Old versions
Topic: swap my decks between 2 & 3
In my skin i have:
1- top left
2- top right
3- bottom left
4- bottom right
I want to modify the skin to replace positions between 2 & 3
Thanks for your help
geposted Fri 20 Jul 12 @ 8:15 am
If I understand you correctly you can do it by unzipping your skin and modifying the xml file an a text editor with find and replace "ctrl + h". I use notepad++, but anything will do.
first you need to make space to move the decks, so find, then replace... and change the deck allocation to something arbitrary that you can easily change later.
deck 2 --> deck x
deck="2" --> deck="x"
deck 3 --> deck y
deck="3" --> deck="y"
that gives you room to move the decks around freely, now do the same again but changing the decks to your preferred layout
deck x --> deck 3
deck="x" --> deck="3"
deck y --> deck 2
deck="y" --> deck="2"
It works,
Thanks
Some textzones, video previews etc may not work as expected though.
In this case you also need to find ..and replace
deck="2" with deck="x"
etc.
or even chan="2" with chan="x" etc
(e.g. for video preview and older codes from old skins)
My apologies, I should have made a new thread first as last.
Is there any way I can remove this post?
I am fairly new to all this, please forgive my ignorance.
Posts can't be deleted, but we have now moderated the duplicate message at your request so that it's no-longer visible.
