Whats going on everyone have a quick question. Was wandering when I go to load a Artist DJ Drop to the sampler it doesn't allow me to load it? It's a WAVE File does that have anything to do with it.
geposted Sat 21 Jul 12 @ 12:42 pm
WAV files play fine in the Sampler. Try playing your sample in a deck to see if it is ok.
geposted Sat 21 Jul 12 @ 1:28 pm
It's wierd cause it just don't show up in the program but if you go and click on start and go to downloads there it is plays for me fine on Quicktime Idont understand but this sucks cause it is for a record debut
geposted Sat 21 Jul 12 @ 6:48 pm
K figured why I couldn't see it but know when ever I play the SAMPLE it is even in the deck it is like all static u can't here any voice and it is an accapella drop so thats wierd any help would be greatly appreciated
geposted Sat 21 Jul 12 @ 6:56 pm
Please check the bit rate and sample rate of the file.
If it's not 16-bit 44.1Khz (Standard audio CD) or 16-bit 48Khz then you may not be able to play it in VirtualDJ. Higher bit rates/sample rates are not currently supported although this may be possible in future versions. However, unless you are playing to a crowd of audiophiles with a very high-end sound system, such high rates are not really necessary for live DJ'ing.
If it is a higher bit rate/sample rate, you will need to use an audio editor such as Audacity to convert it.
geposted Sun 22 Jul 12 @ 6:40 pm
why can't i hear the sample effects on VDJ when i click the green icon.... the sample doesnt play.... HELP!
geposted Thu 04 Oct 12 @ 4:18 pm
You mean on the sample download page of the website?
It's been broken for ages.
People have complained, Atomix know about it, it's still broken!
geposted Thu 04 Oct 12 @ 5:48 pm
