As I searched around the net looking on how to map the XY pad on the nanoPAD2, I realized a lot of people were having the same problem. So here is a quick and simple way to map the nanoPAD 2. Remember, your going to need the pro version of VDJ for this to work properly.
Mapping the pads on the nanoPAD 2 is relatively easy.
Config---->Mappers---->Key Learn (hit the appropriate pad)---> Action Learn (input what you want it to do.)
Now to map the XY pad, it's a little different. Touching the XY pad wont work. It will need to be set up as follows.
X
Config---->Mappers---->Key Learn (type in) 0-CC1---> Action Learn (input what you want it to do.)
Y
Config---->Mappers---->Key Learn (type in) 0-CC2---> Action Learn (input what you want it to do.)
Here is a very basic idea
<map value="0-37" action="hot_cue 1" />
<map value="0-39" action="hot_cue 2" />
<map value="0-41" action="hot_cue 3" />
<map value="0-43" action="hot_cue 5" />
<map value="0-45" action="hot_cue 1" />
<map value="0-47" action="hot_cue 2" />
<map value="0-49" action="hot_cue 3" />
<map value="0-51" action="hot_cue 5" />
<map value="0-36" action="deck 1 eq_kill_low" />
<map value="0-38" action="deck 1 eq_kill_mid" />
<map value="0-40" action="deck 1 eq_kill_high" />
<map value="0-46" action="deck 2 eq_kill_low" />
<map value="0-48" action="deck 2 eq_kill_mid" />
<map value="0-50" action="deck 2 eq_kill_high" />
<map value="0-42" action="sampler default play_stop" />
<map value="0-44" action="deck 2 sync" />
<map value="0-CC1" action="effect slider 1" />
<map value="0-CC2" action="effect slider 2" />
X
Y
geposted Mon 23 Jul 12 @ 2:10 pm
Nice! Thats the one thing i never mapped or could get to work, lol!!
geposted Mon 23 Jul 12 @ 2:59 pm
My VIRTUAL DJ PRO 7 no detect NanoPAD 2 pleeas HELP :(((
geposted Thu 11 Oct 12 @ 12:16 pm
No controllers of any sort will work with the LE version....Upgrade
geposted Thu 11 Oct 12 @ 2:45 pm
you need to be in pro inorder to have this work.. its not a script issue its not being able to use the mapping section. if you have pro it is simple.. you can push the button and then click the thing on the skin you want it to do.. then it will script it for you..
geposted Thu 11 Oct 12 @ 3:59 pm
i have the pro version and my nanopad2 is not shown in the mapper-config :(
WHAT TO DO???
don't let irritate, what my account shows ;)
please help
WHAT TO DO???
please help
geposted Mon 03 Jun 13 @ 9:45 am
Then please register your PRO license so people are not irritated by you showing as a LE user and asking PRO questions.
But to answer the question - the nanoPad 2 does not currently have native support. So, you will need to research the Controller download section to see if there is a user supplied mapping. If so, then you will need to be a registered PRO user to download the mapping.
geposted Mon 03 Jun 13 @ 10:09 am
Hello, i also try to use the nanopad2, but i couldn´t see it within vdj. What should i do?
geposted Sun 05 Jan 14 @ 4:41 am
Nanopad2 is not natively supported, however since the unit has no Leds, you could use it as Simple Midi. You should see the unit detected as Simple Midi in CONFIG->Mappers list
https://virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html
geposted Sun 05 Jan 14 @ 2:00 pm
Thank you ... i will try this tomorrow :-)
geposted Sun 05 Jan 14 @ 3:10 pm
i have korg nano pad 1 and i have vdj 7 pro and i cant map it ...SOME ONE PLEASE HELP ME OUT~!!!!!!!!!!!!!!!!!!!!!!!
geposted Thu 12 Jun 14 @ 8:47 pm
