The club i work at recently installed VDJ (7.0.5b), set up a few skins initially, and then the other night, i tried installing a newer version of the Condensed skin, and after clicking the executable, i looked in the skins screen, and did not see the skin, several more attempts at installing the skin proved unsuccessful. Then I tried installing the Pandoras box effect, and in the effects TAB i can see it on the left, but no way to activate it. Again, I try to install it a few more times, still nothing.
Any help at all would be really appreciated.
geposted Mon 23 Jul 12 @ 4:27 pm
You need to update your windows libraries on your machine. There's a wiki in the plug - ins forum with links to what you need. As for your skins not showing, that's above my pay grade, lol!
Hope that helps
Huey
Hope that helps
Huey
geposted Mon 23 Jul 12 @ 5:32 pm
