what is the best way to hook up 2 computers to my hd 4500
geposted Fri 27 Jul 12 @ 4:07 pm
The newer version of VDJ7 the network part was removed, so the best way is to use USB SWITCH HUB but you can only use this one at a time with a selector to choose which computer you want to use your controller comp-A or comp-B and then single USB out to the controller. At this moment VDJ struggles on auto soundcard configuration setup if you used to switch the USB selector to computer-A or computer-B VDJ freezes or stop working and you can't use any knobs or key on the controller or even on the keyboard unless you go to soundcard config setup and apply the settings again. This idea is possible only to work best with other competitor softwares like TRAKTOR & SERATO ITCH but it does not work on VDJ.
geposted Fri 27 Jul 12 @ 5:03 pm
