Hi there, Thanks for reading my thread, I have recently picked up mixing and have messed around for a couple months with it.
I would be very grateful if you gave my 3rd mix a listen and give me advice, any criticism is welcomed.
Thanks alot.
Mixed using VDJ and Hercules RMX.
Thanks alot.
geposted Fri 27 Jul 12 @ 5:09 pm
Oops, forgot the link!
http://www13.zippyshare.com/v/10494371/file.html
geposted Sat 28 Jul 12 @ 5:59 am
yah, so i listened to your mix and its impressive, but you should layoff the filter for a while and make it a little more dance-able, you get??
geposted Sat 18 Aug 12 @ 10:21 am
