Hi all, i recently bought a Standon DJC4 and i tried mixing and recording my tunes, but i only can record via wav format and its far too huge for my liking, is there any way i can save it via mp3 format?
geposted Sat 28 Jul 12 @ 10:36 pm
convert it in any mp3 converter
geposted Thu 02 Aug 12 @ 7:00 pm
The LE version that came bundled with your Stanton controller, is only supporting recording in wav format.
Recording to mp3, among other features, is only available to Pro Full version.
geposted Thu 02 Aug 12 @ 11:23 pm
Hi Danny
Sorry to sidetrack you away from you issues. I intend to buy the DJC4 as well. But need to find out from you if the VDJ LE version provided works with all the features on the controller apart from your posted problem?
Understand that there will be some limitations on the effects and samples. Can you share with me? Will I be able to fly with only the LE version? Lastly, is the DJC4 a good buy?
Thanks & Cheers
Thanks & Cheers
geposted Thu 06 Sep 12 @ 10:19 pm
