VDJ gives error message that screen res is too low for skin. Res is set to max at 1366x768. VDJ then minimises and will not maximise so I cannot select a different skin. Running Win 7 home Prem 32 bit.
geposted Sun 29 Jul 12 @ 3:59 am
I have the same problem! Help required please.
geposted Sun 29 Jul 12 @ 5:14 am
Re-install VirtualDJ again and it should revert back to the default 1024x768 size.
If not, please perform a clean re-installation of the software:
https://virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20re-installation%20of%20the%20software.html
geposted Mon 30 Jul 12 @ 4:04 am
uninstall reinstall worked, even managed to keep settings and databases. Thanks
geposted Mon 30 Jul 12 @ 11:05 am
