Hey team,
is the reloop terminal Mix 2 also supported by VDJ7 ? I only found drivers, mappers etc for ther terminal mix 4. But I do not rellay need a 4 deck mixer. Any help welcome!
Thanks a lot
T
Thanks a lot
T
geposted Sun 29 Jul 12 @ 10:23 am
It would be fairly easy to modify the TM4 definition to suit the TM2 until atomix release an official one. It would just be a case of changing the device id's (name, driver name & product id "PID"), then making sure the midi messages are the same, if not change them as they both will have exactly the same amount of messages for the same controls as the TM2 is actually switchable to control 4 decks... It would probably take either 5 minutes or an hour to do...
geposted Sun 29 Jul 12 @ 7:23 pm
No, it's not currently supported, but may be in the future.
Please see:
https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
Please see:
geposted Mon 30 Jul 12 @ 4:53 am
Thanks, but in that list the Terminal Mix 4 is also not supported. But the VDJ website recommenda the TM4 onthe Hardware webside.
Can you please comment?
geposted Mon 30 Jul 12 @ 10:14 am
The Terminal Mix 4 is natively supported in VirtualDJ LE that's included with it, but it's newer than the current release of VirtualDJ Pro v7.0.5b, so is not natively supported in Pro yet. However, it is available to install as a separate download for Pro users: https://virtualdj.com/addons/14791/Reloop_Terminal_Mix_4.html
Please see: https://virtualdj.com/wiki/Is%20MIDI%20controller%20NAME%20supported%20by%20VirtualDJ.html
geposted Mon 30 Jul 12 @ 10:23 am
Thanks! Means I can buy it and use it with my VDJ 7.05b Pro, or?
geposted Mon 30 Jul 12 @ 10:27 am
Yes, if you purchase the Terminal Mix 4 and download and install the above mapper then you will be able to use it with your VirtualDJ Pro.
Terminal Mix 2 isn't supported yet (You would need to map it yourself.)
geposted Mon 30 Jul 12 @ 10:41 am
Thank U !!!
geposted Mon 30 Jul 12 @ 11:23 am
