Ok i have the latest updated broadcaster version of Virtual DJ. I currently have a monitor hooked up to my mac i extend the displays. I want to play my video on the other screen but its a small window and when i press activate nothing happens? some of the base plugins it comes with are they good or no good i am confused any help?
geposted Sun 29 Jul 12 @ 1:20 pm
VDJ Broadcaster does not support full screen video
https://virtualdj.com/products/comparison.html
VDJ Pro full does support it.. and more. well worth the extra $$
geposted Sun 29 Jul 12 @ 1:50 pm
thanks so much now... what about like playing you tube videos or downloading from mp3 rocket and putting them on my other monitor? Would that be ok if so how can i keep monitor one going flowing with the music like have a video on deck for each song on you tube or whatever to keep playing?
geposted Sun 29 Jul 12 @ 1:56 pm
any help?
geposted Sun 29 Jul 12 @ 5:09 pm
Greetings. Sounds like you need to upgrade. I use VDJ PRO and have no problems playing videos on my second monitor. I save YouTube videos with Keepvid MP4s @ [Link removed] and they run great. Good luck.
[Please do not post links to illegal and/or commercial tools (See forum rules) - Ripping YouTube videos and playing them at DJ gigs is also illegal. Please use a legitimate DJ service such as PromoOnly for your videos.]
geposted Sun 29 Jul 12 @ 5:24 pm
can't you just use them in a channel?
geposted Sun 29 Jul 12 @ 6:34 pm
hmmm.. think we're gonna need a little more information here. - what exactly are you trying to do? put a video stream online or just localized to monitor? details details details...
geposted Sun 29 Jul 12 @ 6:44 pm
Ok basically I made a playlist I have over 2000+ songs I can use broadcaster I am fine with that. Is there anyway I can scream videos on my mac book while djing on my computer monitor? It is for my brothers kids really to entertain them also for me for more practice. Problem is when the songs done I go to mix and you tube exits out of full screen. I have windows 7 I extended the display any advice?
geposted Sun 29 Jul 12 @ 6:55 pm
Advice 1: Never ever scream at your Mac Book. They don't like that. :)
Advice 2: Upgrade to PRO.
geposted Sun 29 Jul 12 @ 9:41 pm
they are other ways how do you do it besides a upgrade?
geposted Sun 29 Jul 12 @ 10:41 pm
There are no other ways.
If you wish to DJ with videos in VirtualDJ, you will need to upgrade to the full VirtualDJ Professional: https://virtualdj.com/buy/
VirtualDJ LE/Broadcaster/Basic is limited software and is restricted to a small video output window only. See https://virtualdj.com/products/comparison.html
geposted Mon 30 Jul 12 @ 5:07 am
NO NO yes i meant streaming.. there is away huh?
geposted Mon 30 Jul 12 @ 11:44 am
i'm not even close to being an expert on this but i think [I]maybe there might be a way if you had the pro version, to have a fairly robust screen/video capture program taking the feed and streaming it out to a shoutcast server... maybe.
unfortunatly running a stream large enough to be watched in full screen would require a fairly large amount of bandwidth and even with a fast cable modem i think you'd have problems.
speaking of problems how are you going to stream content like music videos and have yourself covered for copyright infringement?
geposted Mon 30 Jul 12 @ 1:32 pm
Well it works I got it kind of working its hard to mix them no they are on youtube its not copyright lol...
geposted Mon 30 Jul 12 @ 6:08 pm
i am using a Mac trying to do video on a tv i cant get the window to get bigger
geposted Thu 27 Sep 12 @ 10:39 pm
You will need to upgrade to the full VirtualDJ Professional at a discount to be able to do this: https://virtualdj.com/buy/
VirtualDJ LE is free limited software and doesn't support full screen video/karaoke output or resizing the video window (Except during the Pro trial) - Please see https://virtualdj.com/products/comparison.html
geposted Fri 28 Sep 12 @ 5:04 am
Hello, I custom built a home pc to dj with online. I also do a VJ mix online as well. Here lately I noticed that some files freeze up to where the audio will play but the video stays frozen. I did take note that the most videos that do this are ones that I have taken directly off of YouTube...why because somethings are very rare and hard to come by...I am wondering is there a solution to this? It has to be something in VDJ that is not right, maybe codec I am not sure. I do notice that I can play all video files but I cannot use the accelerator. If I do use the accelerator I get freeze ups. Any suggestions would be appreciated, and thanks.
PC Spec: i7 - 2600 cpu @ 3.40ghz
RAM - 16gb
System 64-bit OS
Video Card - GeForce GT 520 - Nvidia - Dedicated Memory 1023mb ddr3
RAM - 16gb
System 64-bit OS
geposted Fri 28 Sep 12 @ 9:28 am
