I'm tyring to understand why I get a "Fatal Error" prompt when I click my VDJ Pro 7 icon. It only happens when I connect my Vestax Typhoon. I have installed the ASIO4ALL driver. It also happens when I installed the ASIO for Typhoon driver. VDJ Pro7 works fine when I hook my Mixtrack Pro to it. The Typhoon is fine because it works well with Traktor Pro 2.5. I'm using a Compaq C700, Windows 7, 2GB RAM,
Intel Pentium(R)Dual CPU T2310@ 1.46GHZ, 32 Bit. Can anyone help?
geposted Thu 02 Aug 12 @ 5:36 pm
This happens to me also with a Typhoon...I wasn't sure if it was the Typhoon or the Stanton SC3 system I started using both of them around the time when the problems started, Ive been sending in crash reports like crazy. The controllers don't crash with other software also. Now I cant even open VDJ even without the controller connected.
geposted Thu 02 Aug 12 @ 6:00 pm
I would bet it is a registry issue.....
geposted Thu 02 Aug 12 @ 6:22 pm
before using another controller besides typhoon choose the other controller(if it has built in soundcard)or the soundcard you want to use in vdj sound config menu,disconnect typhonn restart vdj and you are ready togo.......
geposted Fri 03 Aug 12 @ 2:12 pm
