Thought you might be interested in this DIY project. I’m posting progress here:
www.toomuchprojex.blogspot.com
The aim is to try and reduce the amount of gear and the amount of setting up required to do a gig. So, no external hard drive, soundcard, mixer or controller - all in one box! It uses a touchscreen for most controls, and physical buttons and faders for the most often used controls.
I've mocked it up using the excellent touchscreen skin from here - I need to modify it a bit to add an on-screen keyboard, but it's almost there.
Let me know what you think!
geposted Fri 03 Aug 12 @ 10:30 am
Looks really good mate. I would like to use something like this for the same reasons you have listed.
I work for Bosch on the Automotive side. Try having a look at there hardware (DCU130 & KTS670), may give you some other ideas.
will keep a look out for how your getting on.
Best of luck
Iain
Best of luck
Iain
geposted Sat 04 Aug 12 @ 5:54 am
Made alot of progress!
See it here -
http://toomuchprojex.blogspot.co.uk/2012/10/entangled.html
Using it for a gig tomorrow - so i\'ll report on how it went...
Cheers
Sam
See it here -
Cheers
Sam
geposted Fri 05 Oct 12 @ 6:28 am
Always wanted to do this, well just the MIDI controller part. I love the stuff you cats come up with.
Nice work & Keep us informed
Huey
Huey
geposted Sun 07 Oct 12 @ 9:32 pm
first video posted
more to follow over the weekend hopefully
http://toomuchprojex.blogspot.co.uk/2012/10/video-killed-blogstar.html
Sam
Sam
geposted Fri 12 Oct 12 @ 2:57 pm
the video at the site is private
geposted Fri 12 Oct 12 @ 3:10 pm
public now...
geposted Fri 12 Oct 12 @ 3:56 pm
