I ran video and karaoke last night with minimal problems. No problem with karaoke at all.
I had slight issues with video. Some of my videos would skip and they were not fluid. Backspins and scratches were bad looking.
How can I fix this?
I have a POWERFUL macbook pro.
2.5Ghz quad core i7 with 16gb memory.
VDJ ran very good last night with this machine. I used my NS6. Scratching was not perfect but it was not very horrible. I would like to tighten the scratch up but i NEED video to run smooth.
A little help please?
Full specs...
MacBook Pro 2.5GHz Quad-core Intel i7 (Lion)
Originally released October 2011
15.4-inch (diagonal) LED-backlit Hi-Res antiglare widescreen display, 1680-by-1050 resolution
4GB (2 x 2GB) of 1333MHz DDR3 SDRAM
750GB Serial ATA @ 5400 rpm
8x double-layer SuperDrive (DVD±R DL/DVD±RW/CD-RW)
Intel HD Graphics 3000 and AMD Radeon HD 6770M
How can I fix this?
Full specs...
geposted Fri 03 Aug 12 @ 12:14 pm
Let me clarify an earlier statement.
"I had slight issues with video. Some of my videos would skip and they were not fluid. Backspins and scratches were bad looking."
Video would skip but audio was fine. No skip in audio, just video.
Backspins, weather fast, slow or very slow were not just bad but VERY bad on video. Audio was fine.
Scratching was also very bad on video. Audio was fine.
I do not have auto graphics switching enabled. I unchecked that the day I purchased the macbook.
geposted Fri 03 Aug 12 @ 12:19 pm
No help for me???
Let me clarify further...
While running music videos, I had videos skipping and looking bad while scratching and backspins.
Karaoke looked good. I did not see any skipping with karaoke but then again, there is no need to scratch karaoke or do backspins.
I really need some help with this.
geposted Sun 05 Aug 12 @ 2:55 pm
There's plenty of threads that clear this up, already. Go into your video options and check the "decode while hidden" box. It lets the video load and play smoothly while the crossfader is over on the other deck. It's almost like video not playing is getting a virtual run through. That's what worked for me and that's the advice I've given before, seems to work. hit me up if there's more issues.
geposted Fri 10 Aug 12 @ 6:16 am
Thank you cguild...
I will give it a try and let you know if it gets better.
geposted Sun 12 Aug 12 @ 12:45 pm
That is right I had that same issue also and if you started it in the middle of a video that over 12min+ give and take the word will not be with the song.
geposted Mon 13 Aug 12 @ 1:36 pm
