hi there can some one help me,,
i am wondering if the ddj ergo has a option , when a track is on cue on the left deck and i play a track on the right, if i slide the cross fader over to the left will it kick in automaticly, im using virtual dj pro,,,
thanks,
thanks,
geposted Sat 04 Aug 12 @ 7:29 am
All you will have to do is change the crossfader mapping action. Follow the link bellow.
https://virtualdj.com/wiki/Fader%20start%20using%20the%20crossfader.html
geposted Sat 04 Aug 12 @ 8:48 am
thanks for that pal,
geposted Sat 04 Aug 12 @ 8:52 am
if i change the mapping, can i still fade in and out as normal,
geposted Sat 04 Aug 12 @ 9:26 am
Yes, try and see it for yourself. Also, the tutorial shows an option with on/off fader start.
geposted Sat 04 Aug 12 @ 1:39 pm
You can create a shortcut for fader_start to
geposted Sat 04 Aug 12 @ 1:41 pm
The one that I did makes it so you will only start the correct deck when moving off 0% or 100%, it won't actually stop the deck from playing on either side. The other thing you can do is move off either end to start the deck, but then return to the same end with the playback continuing, I didn't like the way the built in one works so came up with that.
It is always setting the variables for the faderstart so you can turn it on at any time (after you have moved the crossfader to one end for the first time) and it will work.
geposted Sat 04 Aug 12 @ 11:06 pm
