I have 2 serial# for Virtual DJ Pro, (I have 2 setups both with a backup laptop), but I don't seem to be able to locate the serial# anywhere in the software?
Its need to identify the serial, so that I can use the correct serial,- as the user agreement allows 1 active and one backup install pr. serial.
Any ideas?
Any ideas?
geposted Tue 07 Aug 12 @ 5:08 pm
If you bought both licences with the same account, both serials are >here<
geposted Tue 07 Aug 12 @ 6:20 pm
Please also ensure that you also download and use the correct installation file for each serial number.
If you have purchased two or more licenses, then there will be separate download links in each serial number's section of your Download Center page.
geposted Wed 08 Aug 12 @ 5:50 am
djgmg wrote :
.... but I don't seem to be able to locate the serial# anywhere in the software? .....
Thats right, YOU can't see it inside software VDJ.
The only way would be to use a paper or a other document to know what serial is used for a computer.
Serial 1 -> 1st Computer (acer)
Serial 1 -> 1st Backup (msi)
Serial 2 -> 2nd Computer (Mac)
Serial 2 -> 2nd Backup (HP)
Please do not put it on a sticker and this one onto the computer ;-)
Keep it at home in a box or something simular.
geposted Wed 08 Aug 12 @ 6:29 am
