I am using the basic 2 player VDJskin 7.0.3.
As a standard, the blue/red rhythm waves for both players overlay each other.
I would like to split the two rhythm waves (not including the computer beat grids), and have the player 1 blue wave on the top half of the rhythm window, and player 2 red waved on the bottom half of the window.
The red/blue computer beat grids should remain at their current location (overlaying each other in the bottom of the window).
Could someone please show me with the script that will do this?
Thanks in advance,
Clay
Thanks in advance,
Clay
geposted Tue 07 Aug 12 @ 5:23 pm
that's not a big deal
first i need to know is it the basic skin from vdj.
second what is the resolution of the skin your using.
and have you tried making a skin for yourself.
let me these i can help you
geposted Wed 08 Aug 12 @ 9:19 am
The skin resolution is 1024x768.
Yes I have tried modifying the skin with no luck.
Thanks for the response,
Clay
Clay
geposted Wed 08 Aug 12 @ 12:20 pm
here you go but before going ahead suggest you to make a back up of the skin file u'r editing
i still remember the days of hard work getting screwed in just one simple mistake
just open xml file in note pad & find this part
<rhythm pannel="Rhythm">
<size width="940" height="45"/>
<pos x="40" y="35"/>
*** BLUE ***
<chan1_active1 x="40" y="1430"/>
<chan1_active2 x="40" y="1900"/>
*** RED ***
<chan2_active1 x="40" y="2036"/>
<chan2_active2 x="40" y="930"/>
*** OVERLAY ***
<both_active1 x="40" y="1970"/>
<both_active2 x="40" y="2105"/>
<grid1 width="5" mainwidth="11">
<size width="950" height="5"/>
<pos x="40" y="85"/>
<active1 x="40" y="1430"/>
<active2 x="40" y="1900"/>
</grid1>
---- GRID ------
<grid2 width="5" mainwidth="11">
<pos x="40" y="90"></pos>
<active1 x="40" y="2036"/>
<active2 x="40" y="930"/>
</grid2>
---- CUE MARKERS ------
<cue1>
<size width="940" height="50"/>
<pos x="40" y="26"/>
<down x="40" y="1430"/>
<mask x="602" y="2195" width="13" height="14"/>
<text dx="9" dy="0" font="LCD" size="12" color="#B0E0FF"/>
</cue1>
<cue2>
<down x="40" y="2106"/>
<text dx="9" dy="0" font="LCD" size="12" color="#FF6868"/>
</cue2>
</rhythm>
and then replace the whole thing with the below part
whole thing if you miss one single letter then u'll see invalid skin line error
it's difficult to find what went wrong
<size width="940" height="34"/>
<pos x="40" y="25"/>
<chan1_active2 x="40" y="1430"/>
<chan2_active1 x="40" y="25"/>
<chan2_active2 x="40" y="25"/>
<both_active1 x="40" y="1430"/>
<both_active2 x="40" y="1430"/>
<size width="950" height="2"/>
<pos x="40" y="93"/>
<active2 x="40" y="1430"/>
</grid1>
<cue1>
</cue1>
</rhythm>
<pos x="40" y="59"/>
<chan1_active1 x="40" y="25"/>
<chan1_active2 x="40" y="25"/>
<chan2_active1 x="40" y="930"/>
<both_active1 x="40" y="930"/>
<both_active2 x="40" y="930"/>
<pos x="40" y="96"></pos>
<active1 x="40" y="930"/>
</grid2>
<cue2>
<pos x="40" y="60"/>
</cue2>
</rhythm>
this is a result of tested & it's working fine with my skin
hope you like it & it's what you wanted
play around the skin it's fun making it "remember to make a backup of the file"
enjoy peace & out
Dj Pradeep
*** BLUE ***
*** RED ***
*** OVERLAY ***
</grid1>
---- GRID ------
</grid2>
<cue1>
</cue1>
<cue2>
</cue2>
</rhythm>
</grid1>
<cue1>
</cue1>
</rhythm>
</grid2>
<cue2>
</cue2>
</rhythm>
enjoy peace & out
Dj Pradeep
geposted Thu 09 Aug 12 @ 2:09 am
DJ Pradeep, Thanks so much for your help!
The waveform XML works on my machine almost perfectly except;
The red waveform displays, but the wave peaks (top half of red wave), and the red cue markers are flashing between bright red and dim red.
The blue Computer Beat Grid (CBG) at the bottom is also flashing in time with the red waveform peaks.
The red waveform works great if it is the only one displayed, but once I load the blue waveform, the red waveform starts flashing.
The blue waveform is always stable and works great.
I have a 1024x768 resolution.
You or anyone else have any ideas on what’s wrong?
Thanks again,
Clay
Thanks again,
Clay
geposted Thu 09 Aug 12 @ 6:06 pm
thank's for tring out. i'm sorry i've the same glitch in my skin
the thing is i forgot to change the cue size.
just replace this for 1st cue section
<cue1>
<text dx="9" dy="0" font="ARIAL GREEK" size="12" color="#B0E0FF"/>
</cue1>
and just replace this for 2nd cue section
<cue2>
<text dx="9" dy="0" font="ARIAL GREEK" size="12" color="#FF6868"/>
</cue2>
see my skin's here
http://img38.imageshack.us/img38/7986/pioneercdj2000djm900nex.jpg
facebook a/c name Pradeep L B Naidu
http://img163.imageshack.us/img163/2578/pioneercdj400jukeboxbig.jpg
<cue1>
</cue1>
<cue2>
</cue2>
see my skin's here
geposted Sat 11 Aug 12 @ 3:26 am
DJ Pradeep, thank you so much for your help.
It works great now using those xml cue modifications!
Great job.
Thanks again,
ClayDJ
Great job.
Thanks again,
ClayDJ
geposted Sat 11 Aug 12 @ 6:58 pm
your most welcome
geposted Mon 13 Aug 12 @ 6:46 am
