I have a Digital Jockey 2 ME (2.9.14), and I wish to use it with VDJ 7.0 what are the steps? Do I need to make any firmware update? Where can i find the maps?
I have a gig tonight, so if you can give me the direct links I would apreciate.
all the best
all the best
geposted Wed 08 Aug 12 @ 11:28 am
v7.0.0 is an old and out of date version of the software. There have been many changes and improvements to the software since then including built-in native support for the Digital Jockey 2 (See VirtualDJ history and supported controllers) - We are now on v7.0.5b
Please register your Pro serial number on the page https://virtualdj.com/users/edit.html and then upgrade to the latest version: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/
NOTE: Nobody will give you any links or send you mappers. This is not permitted for unlicensed users. Besides, what you are asking for is already built into the software. You should also not be making major changes to your system just prior to going to a gig. Wait until afterwards when you have plenty of time to configure/test/check everything and get used to your new setup.
geposted Wed 08 Aug 12 @ 11:52 am
