Hi all, I've just bought a Korg NanoKontrol to go with my Numark DJ2Go, and I'm having trouble mapping it so it switches between decks 1 and 3, and 2 and 4. Basically I want it so when I press the PFL buttons on each side, it selects deck 1 or 2 (top left or right) respectively as the working deck. And then I wanna map two keys on the Nano to select 3 or 4.
I've been trying to map it for a while now, and i think the issue is that the two PFL buttons aren't separated by a different name. So there is only one Key: PFL, and one Action: Select, yet they work in the parameter of their own side. I don't know if all controllers are like this, but I wanna map it so it's split up. Cause right now, the Nano keys work fine in selecting 3 and 4, but when I do that, the PFL key on the DJ2Go only selects deck 1, and not 2.
Aaargh, this hurts my brain. Some help or insight please? Maybe there's a simpler way?
geposted Wed 08 Aug 12 @ 6:38 pm
I'm not sure your version supports that controller. What version are you using? If it came with a controller, you should register it.
geposted Thu 09 Aug 12 @ 2:06 pm
