Hi
I've managed to install Virtual DJ on my new Macbook and I am amble to use my Denon 4500 controller with no problems....well one problem. I can play the songs but I can't see anytyhing on the display of the controller itself I do not know why this is happening and I've tried everything I can think of.
Can someone help?
I am using Mountain Lion.
Thanks
Can someone help?
Thanks
geposted Sat 11 Aug 12 @ 12:41 pm
Make sure that you have the latest firmware loaded from http://www.denondj.com
Also, check with the manufacturer that it's compatible with Mountain Lion. It may not be fully compatible with this new OS yet.
geposted Sat 11 Aug 12 @ 1:24 pm
I updated the firmware and problem solved.
So anybody out there who used the 4500 with a Mac make sure you have firmware version 1006
THANKS
DJ JumpinJim
THANKS
DJ JumpinJim
geposted Sat 11 Aug 12 @ 3:47 pm
