My situation is as follows:
I have a "playlist" in iTunes that is virtually a collection of songs I'm able to use for a specific event. I started to make a playlist in Virtual DJ by dragging the songs from the main middle panel into the right playlist panel. I saved this and it was my hope that I would continue to update my playlist in this way. However, it appears as though I can now only select one or the other.
So my question is probably obvious: is it possible to play with both again? I would like to be able to load my itunes playlist in the center while updating my Virtual Dj playlist on the right. Please tell me there is a way to see both and that I won't have to manually create my old playlist in order to update it.
I apologize if this question has been asked to no end. I tried searching but I was not satisfied that the question had been answered in regard to my issue.
geposted Tue 14 Aug 12 @ 12:33 pm
Basically you need to highlight your playlist in iTunes from within VDJ, Make a folder with the exact iTunes name in VDJ, highlight the browser content and drag all the iTunes media into the newly created playlist folder in VDJ.
You will have to manually due the updates, quick way would be to sort by date on both iTunes and VDJ to make it easier for you to just target only newly added tracks that are Not in your VDJ folder, then highlight those in the browser and migrate into VDJ folder you created earlier...
Good Luck,
Joey...
Good Luck,
Joey...
geposted Tue 14 Aug 12 @ 1:50 pm
