Hi,
I'm new to VDJ, I've got an external mixer with a 4.1 sound card... how do you make a recording with the gain levels if you're doing it from the external mixer?
Thanks
Tom
Thanks
Tom
geposted Thu 16 Aug 12 @ 7:52 am
First, to be able to output two decks separately to an external mixer, you will need to purchase either VirtualDJ Basic or the full Professional. Please see comparison.
For recording when using an external mixer, please see our FAQ pages:
https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
geposted Thu 16 Aug 12 @ 9:37 am
Thanks - just making sure it was possible before making the purchase... what's the Booth output (as my mixer (Stanton SMX-201) doesn't have a rec out)
Tom
Tom
geposted Thu 16 Aug 12 @ 4:23 pm
If you want to do recording alone you can take the recording output from your Stanton Mixer Main Outs and connect it to your Recorder Inputs. But if you want to record your live performance and at the same time you want to record it while you are playing then you need a mixer which has a recording output or a soundcard that has an extra channel output that can be use for recording. You can also try and buy VDJ Pro V7 has the audio recording features you can record your song directly into your hard drive while you are playing.
geposted Thu 16 Aug 12 @ 7:08 pm
Hey do you know how I would be record my mixes without my pfl playing over the track I'm playing out, Ive tried everything! I have a stanton mixer and virtual dj pro 7...I have changed every single config I could and Ive plugged my wires into the back on my mixer into record and it still plays the pfl as I'm cueing up the tracks? I have no idea what to do.
geposted Thu 11 Oct 12 @ 8:34 am
As already posted above, please our FAQ pages on this subject:
Please also register your Pro serial number on the page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it.)
geposted Fri 12 Oct 12 @ 5:25 am
