Hey guys
I have a question about the Sonique effcet: Is there a mapping code out which allows me to load a "sample" (one of the files from here : https://virtualdj.com/addons/4207/72_Sonique_Visual_plugins_certified.html) and play it??
I tried everything.... please help :-)
Greets from bavaria
chrisXD
Greets from bavaria
chrisXD
geposted Thu 16 Aug 12 @ 3:07 pm
there are a few ways to do this.....
put the soniques in the video efx folder , then select soniques, activate and pick a particular one manually
you could record them with video software and then load them in the clip bank
and if you recorded them as stated above then you could link the video to the song
if you go thru the soniques one by one and eliminate the boring ones you'll be glad you did....
out of the original 84? i whittled it down to 60 and now i don't use them much maybe just an A list
of 10 or so
linking the vids and clips to songs is a lot of fun ......
of 10 or so
geposted Fri 17 Aug 12 @ 11:56 am
hey :-)
Thanks for your answer !
I will try to record the vids :D
greets
chrisXD
greets
chrisXD
geposted Fri 17 Aug 12 @ 3:20 pm
I wonder if something similar to this .. https://virtualdj.com/forums/151759/General_Discussion/mapping_beatgrid_presets.html could work for your case
geposted Fri 17 Aug 12 @ 6:10 pm
yeah :D thanks a lot !!
thats exactly what i wantet !! :-)
greets
chrisXD
greets
chrisXD
geposted Sat 18 Aug 12 @ 3:32 am
