I run a MacBook Pro with OS X 10.5.8 and I recently purchased a DJ:IO to go with my Numark Mixtrack. I installed the driver for the DJ:IO and restarted my computer. I plugged the DJ:IO in and it starts flashing, then I opened Virtual DJ LE and it does not appear in my output options. I assumed this problem has something to do with the driver for the DJ:IO so I uninstalled and reinstalled the driver, but it still does not recognize the soundcard. I have contact Numark who did not answer, so I have turned to this forum for help. Any ideas? Is there any way to configure my computer to recognize the DJ:IO? Thanks.
geposted Fri 17 Aug 12 @ 2:49 pm
The DJio is an external sound card and therefore will not work with LE. The LE version you have will only work with the mixtrack controller it is supplied with, so if you want to use another sound card or multiple cards you will have to upgrade to Virtual DJ Pro.
If you enter your LE serial on this site you will get a discounted price for upgrading to VDJ Pro.
Keith
Keith
geposted Fri 17 Aug 12 @ 3:07 pm
I understand that, but my computer should still recognize the soundcard in the system preferences>sound>output pane. The computer itself does not recognize the soundcard, not just the VDJ LE. What could be the problem then?
geposted Fri 17 Aug 12 @ 4:50 pm
This may be a driver issue - Download and install the latest drivers from http://www.numark.com/djio
If that doesn't help, please contact the manufacturer Numark support for assistance: http://www.numark.com
NOTE: If you have the normal MixTrack (Non-Pro model), then the DJIO can be used with its VirtualDJ LE. If you have the MixTrack Pro then the DJIO cannot be used. MixTrack Pro has its own built-in sound card which you must use instead (Unless you upgrade to the full VirtualDJ Pro.)
geposted Fri 17 Aug 12 @ 5:11 pm
