Topic: Where do i find my serial number
Hey guys well i got the pioneer DDJ-ERGO (Really Happy with it) and it came with Virtual dj LE
and i lost the serial number :( so where can i find my serial number.
geposted Sat 18 Aug 12 @ 10:28 pm
You'll have to contact Support, they are the only ones who can help you.
Sorry guys i dident look hard just found the disk pack under my computer
I was about to tell you to check there... :-P
Seriously, though...vDJ is a great product and I HIGHLY recommend upgrading to pro when you get the chance!
how can I find the series key.
If you have an LE version the serial number should be printed or stuck to the CD sleeve that came with your controller.
If you bought Pro through the web site your serial number will be found under your profile.
That said, if you had purchased Pro, your profile status would automatically update to Pro level.
Cheers,
Roy
where do i find my serial number??
Hey Guys,
Where i can find my serial number to download virtual dj le
Just click on download center as you are already registered.
Keith
Hey I lost my CD sleeve but not the CD, for the numark dj2go. is there any way to retreive my serial number?
You have registered the LE keycode/serial to your Account, so just head to https://virtualdj.com/users/edit.html and click on "My Licenses" tab on the right side to get the latest available LE build along with your serial.
Hey guys,
i've used Virtual DJ 7 with my DDJ ERGO V controller it got a LE serial number, but that number doesn't work with Virtual DJ 8?
I've uninstalled my virtual dj by accident and now I need my serial number to re-install but I can't find it wat do I do? I wouldn't mind just buying another disc but I can't even find that I'm an amateur dj can somebody please help me out!
If you read this thread, you will find the answer to your question, before you even post it.
LOCKED BY AMAHM
